Текущее время: 26 май 2026 18:15
 Заголовок сообщения: a1278 820-2936 icore 5 slow bootin on battery
СообщениеДобавлено: 21 окт 2015 23:34
hello
i have 2 laptop both work fine when the adapter is pluged on when u disconnect adapter and run on. battery the machine takes too much time to boot,also. thr trackpad does get jittery and freezing but with adapter is works perfect. anyone face this problem or what i can i check as i have changed trackpad, smc chip, new hdd disconnected the wifi and camera cable
thanks
 Заголовок сообщения: Re: a1278 820-2936 icore 5 slow bootin on battery
СообщениеДобавлено: 22 окт 2015 11:17
guruji писал(а):
hello
thanks
Good afternoon! Check the accumulator, sometimes happens because of the faulty battery the notebook brakes
Зарегистрированные пользователи: Google [Bot], hotlin, Yandex [Bot]
