Текущее время: 26 май 2026 13:14
 Заголовок сообщения: mbp a1278 2012yr slow boot
СообщениеДобавлено: 18 авг 2017 23:27
hi all i have a a1278 mbp 820-3115-a there was a charging issue which i fixed. now the problem is that the fan is very fast and the cpu is full throttle even when idle.I have got all the sensor reading and they look normal i also changed the smc.
yes there was some corrosion on the board which i washed it but same issue.Where is the problem ?????
