Текущее время: 15 июн 2026 02:30
 Заголовок сообщения: Apple Hardware Test (AHT) все версии
СообщениеДобавлено: 19 ноя 2014 21:54
кому нужен AHT гляньте сюда: https://mega.co.nz/#F!98gDDa5D!qIFxH8trvV42kigvzGKVFA
расшифровка версии:
Apple Hardware Test 3A148 supports
MacBook Pro (15-inch, Late 2008) systems where the third, fourth, and fifth digits of the serial number are below "911"
Apple Hardware Test 3A207 supports
Mac Pro (Mid 2010)
Mac Pro (Mid 2012)
Apple Hardware Test 3A202 supports
iMac (27-inch, Mid 2010)
Apple Hardware Test 3A195 supports
iMac (21.5-inch, Mid 2010)
Apple Hardware Test 3A107 supports
MacBook Pro
MacBook Pro (15-inch, Glossy)
Apple Hardware Test 3A115 supports
MacBook Pro (15-inch, Core 2 Duo)
Apple Hardware Test 3A173 supports
MacBook Pro (13-inch, Mid 2009)
Apple Hardware Test 3A192 supports
MacBook Pro (13-inch, Mid 2010)
Apple Hardware Test 3A168 supports
iMac (20-inch, Mid 2009)
Apple Hardware Test 3A114 supports
MacBook (13-inch, Late 2006)
Apple Hardware Test 3A244 supports
MacBook Air (11-inch, Mid 2012)
MacBook Air (13-inch, Mid 2012)
MacBook Pro (13-inch, Mid 2012)
MacBook Pro (15-inch, Mid 2012)
MacBook Pro (Retina, Mid 2012)
MacBook Pro (13-inch, Retina, Late 2012)
MacBook Pro (15-inch, Retina, Early 2013)
MacBook Pro (13-inch, Retina, Early 2013)
Mac mini (Late 2012)
Mac mini Server (Late 2012)
iMac (21.5-inch, Late 2012)
iMac (27-inch, Late 2012)
iMac (21.5-inch, Early 2013)
Apple Hardware Test 3A160 supports
MacBook Pro (17-inch, Late 2008)
MacBook Pro (17-inch, Early 2009)
Apple Hardware Test 3A128 supports
MacBook (13-inch, Mid 2007)
Apple Hardware Test 3A162 supports
MacBook (13-inch, Aluminum, Late 2008) with serial numbers where the third, fourth, and fifth digits are equal to or higher than "911".
Apple Hardware Test 3A153 supports
Mac Pro (Early 2009)
Apple Hardware Test 3A150 supports
Mac mini (Early 2009)
Mac mini (Late 2009)
Apple Hardware Test 3A156 supports
iMac (20-inch, Early 2009)
Apple Hardware Test 3A157 supports
iMac (24-inch, Early 2009)
Apple Hardware Test 3A102 supports
Mac mini (Early 2006)
Mac mini (Late 2006)
Apple Hardware Test 3A147 supports
MacBook (13-inch, Aluminum, Late 2008) with serial numbers where the third, fourth, and fifth digits are below "911".
Apple Hardware Test 3A163 supports
MacBook Pro (15-inch, Late 2008) with serial numbers where the third, fourth, and fifth digits are equal to or higher than "911"
Apple Hardware Test 3A165 supports
MacBook (13-inch, Early 2009)
MacBook (13-inch, Mid 2009)
Apple Hardware Test 3A171 supports
MacBook Pro (15-inch, Mid 2009)
Apple Hardware Test 3A151 supports
MacBook Air (Late 2008)
MacBook Air (Mid 2009)
Apple Hardware Test 3A172 supports
MacBook Pro (15-inch, 2.53GHz, Mid 2009)
Apple Hardware Test 3A181 supports
MacBook (13-inch, Late 2009)
Apple Hardware Test 3A188 supports
iMac (27-inch, Late 2009)
Apple Hardware Test 3A189 supports
iMac (21.5-inch, Late 2009).
Apple Hardware Test 3A141 supports
iMac (17-inch, Late 2006, CD)
iMac (20-inch, Mid 2007)
iMac (24-inch, Mid 2007)
Mac mini (Mid 2007)
Mac Pro
Mac Pro (8x)
MacBook (13-inch, Late 2007)
MacBook Pro (15-inch, 2.4/2.2 GHz)
MacBook Pro (17-inch, 2.4 GHz)
Apple Hardware Test 3A105 supports
MacBook Pro (17-inch)
Apple Hardware Test 3A131 supports
MacBook Air (original)
Apple Hardware Test 3A134 supports
MacBook Pro (15-inch, Early 2008)
Apple Hardware Test 3A135 supports
MacBook Pro (17-inch, Early 2008)
Apple Hardware Test 3A146 supports
Mac Pro (Early 2008)
Apple Hardware Test 3A143 supports
MacBook (13-inch, Early 2008)
MacBook (13-inch, Late 2008)
Apple Hardware Test 3A139 supports
iMac (24-inch, Early 2008)
Apple Hardware Test 3A138 supports
iMac (20-inch, Early 2008)
Apple Hardware Test 3A103 supports
iMac (17-inch, Early 2006)
iMac (20-inch, Early 2006)
Apple Hardware Test 3A104 supports
MacBook (13-inch)
Apple Hardware Test 3A108 supports
iMac (17-inch, Mid 2006)
Apple Hardware Test 3A110 supports
iMac (17-inch, Late 2006)
Apple Hardware Test 3A111 supports
iMac (20-inch, Late 2006)
Apple Hardware Test 3A113 supports
iMac (24-inch)
Apple Hardware Test 3A191 supports
Mac mini (Mid 2010)
Apple Hardware Test 3A199 supports
MacBook (13-inch, Mid 2010)
Apple Hardware Test 3A186 supports
MacBook Pro (15-inch, Mid 2010)
Apple Hardware Test 3A185 supports
MacBook Pro (17-inch, Mid 2010)
Apple Hardware Test 3A116 supports
MacBook Pro (17-inch, Core 2 Duo)
Apple Hardware Test 3A222 supports
MacBook Pro (13-inch, Late 2011)
MacBook Pro (15-inch, Late 2011)
MacBook Pro (17-inch, Late 2011)
Apple Hardware Test 3A224 supports
Mac mini (Mid 2011)
Apple Hardware Test supports
iMac (21.5-inch, Late 2011)
Apple Hardware Test 3A223 supports
MacBook Air (11-inch, Mid 2011)
MacBook Air (13-inch, Mid 2011)
Apple Hardware Test 3A213 supports
iMac (27-inch, Mid 2011)
Apple Hardware Test 3A209 supports
MacBook Pro (15-inch, Early 2011)
Apple Hardware Test 3A211 supports
MacBook Pro (17-inch, Early 2011)
Apple Hardware Test 3A208 supports
MacBook Pro (13-inch, Early 2011)
Apple Hardware Test 3A204 supports
MacBook Air (13-inch, Late 2010)
Apple Hardware Test 3A205 supports
MacBook Air (11-inch, Late 2010)
Apple Hardware Test 3A212 supports
iMac (21.5-inch, Mid 2011)
