Текущее время: 15 июн 2026 02:31
 Заголовок сообщения: imac a1312 820-2901
СообщениеДобавлено: 24 янв 2018 17:33
hello
i have an imac 820-2901 only when i remove the cmos battery it starts to work and i get display but when i put cmos battery i get s5 power but when i press power switch it does not turn on.if i remove the cmos then again it works properly you can also power it off and on ,no problem.where i the problem
thanks
