Текущее время: 26 апр 2026 23:10
 Заголовок сообщения: Asus bios n75s
СообщениеДобавлено: 27 мар 2013 01:43
hi plz i want bios asus n75s. thanks
 Заголовок сообщения: Re: Asus bios n75s
СообщениеДобавлено: 30 мар 2013 19:59
hi
her driver bios for asus n75s
1、Please Verify the exact model and download the latest BIOS file for your PC from ASUS Download
site.
Please ensure that you have installed Winflash Utility before using update procedure. You may
install the program via Driver & Utility CD if you can't find the program from
Start->All Programs
Then execute the auto-extract file to a temporary folder.
Click Start\ALl Programs\ASUS Utility\WINFLASH\WINFLASH
2、Select and open the updated BIOS image fils.
3、Please confirm the loaded BIOS information.
Check out model/version/data.
4、Press Flash to initialize BIOS updating procedure.
5、Press Exit when procedure completes.
6、Please reboot the system.Assuming that you have successfully flashed the BIOS file, press DEL
to enter BIOS setup page when ASUS white logo appears during system Boot-up procedure.
7、After entering BIOS setup page, please go to Exit sub-menu and choose "Load Optimal Defaults".
Then click "Save and Exit" and reboot system again. The BIOS flash procedure is no complete
