Текущее время: 22 май 2026 07:52
 Заголовок сообщения: HELP bios dump elitebook 2570p i7
СообщениеДобавлено: 13 июл 2014 02:50
Hello,
I need bios dump for an elitebook 2570p i7
Please help!!!
 Заголовок сообщения: Re: HELP bios dump elitebook 2570p i7
СообщениеДобавлено: 13 июл 2014 02:57
Describe the problem, and upload your original backup.
СообщениеДобавлено: 13 июл 2014 03:45
There is an bios password set so i need a clean dump,
i haven't got the Original dump yet, i thaught first i need clean dump.
СообщениеДобавлено: 13 июл 2014 05:41
viewtopic.php?f=387&t=66048&p=559933&hilit=%2A2570p%2A#p559933
СообщениеДобавлено: 13 июл 2014 07:35
Here is full Dump & EC dump.
techman1025
СообщениеДобавлено: 13 июл 2014 16:50
techman1025
Techman1025 thank you,
but is the Original dump not 16 mb?
and what is ec dump?
thank's
СообщениеДобавлено: 13 июл 2014 17:23
Are you eyeless???
Get your full dump from the link!
СообщениеДобавлено: 13 июл 2014 19:21
тагансити писал(а):
Are you eyeless???
Hi тагансити,
Yes i saw that but it was for an i3 processor is that no problem for me?
THANK YOU!!
СообщениеДобавлено: 13 июл 2014 20:07
Do'nt worry (be happy :) ). Try to flash...
If any problem exists, post here.
Save backup first!!!
zenelli писал(а):
where is the password set on the bios dump? wich field i must rewrite with zero's to clean bios password?
I think, you must rewrite ME Region...
Where is your original backup??? Is the uploading so difficult? :sh_ok:
СообщениеДобавлено: 13 июл 2014 23:33
Hi
Hp has a full update's with new clean ME Reion...no need to do anything just uncompress it after download if your original file is different in size up load it i will compare it with update after unpacking it from hp then some file are decrypted and you need the pheonix 2.50 thats all no need to do anything beleave me i do this for a living ;)
techman1025
СообщениеДобавлено: 15 июл 2014 00:28
hello,
I'm not a professional so i don't know everything, what is ME region?
I haven't got time to dismantle the laptop and search the bios chip so i haven't got the Original bios dump,
Do you know maybe where i must seek to? :-)
СообщениеДобавлено: 15 июл 2014 00:33
Hi
techman1025
hello,
but then i think are the serial numbers and the rest of the numbers are gone of the bios, and i know there is a tool for it to write it back,
but i was thinking maybe someone know where exactly the password is stored wich offset on the dump so i can change it that's so much easy i think
СообщениеДобавлено: 15 июл 2014 01:08
zenelli писал(а):
I'm not a professional ...
I haven't got time to dismantle the laptop and search the bios chip...
...that's so much easy i think
Go to official HP service, it's so much easy...
