Текущее время: 26 апр 2026 17:41
 Заголовок сообщения: Bios dump hp folio 9470m bios dump
СообщениеДобавлено: 08 авг 2014 19:53
Has someone bios dump for me for an HP folio 9470m? :)
 Заголовок сообщения: Re: Bios dump hp folio 9470m bios dump
СообщениеДобавлено: 08 авг 2014 20:52
Upload your original backup, and describe the problem.
СообщениеДобавлено: 09 авг 2014 23:35
HI,
here it is
can you maybe tell me where the password line is :)
or pm me
http://www.mediafire.com/download/2a05i ... backup.bin
СообщениеДобавлено: 09 авг 2014 23:39
Problem is there is an bios password set i can't get in to bios
СообщениеДобавлено: 10 авг 2014 05:17
Try to flash.
СообщениеДобавлено: 10 авг 2014 23:46
thank's тагансити
i have only one problem i can't flash it back. my programmer (sofitech sp8-A)
doesn't really support the bios chip (winbond 25Q128fvsg)
I could only read the chip but deleting or programming does not work.
Do you know maybe a good programmer?
Thank you very much!!
СообщениеДобавлено: 11 авг 2014 03:12
Don't know your budget...
EZP2010 Support Device List
TL866A Support Device List
etc...
СообщениеДобавлено: 11 авг 2014 21:15
TL866A MINIPRO i have that too, but also not supporting.
I'm not a professional but on Flypro programmer i can choose from W25Q128FV,W25Q128FV (SOIC8),W25Q128FV(WSON 6X5),W25Q128FV(WSON 8X6),W25Q128FV(WSON 16),W25Q128FV (ISP).
So the Original chip W25Q128FVSG is not there.
I'm using for programming an eeprom clip so i do directly on the motherboard without removing the chip from board is that the problem maybe?
But on elitebook 8440p that was not an problem.
СообщениеДобавлено: 11 авг 2014 21:44
zenelli писал(а):
i do directly on the motherboard without removing the chip from board is that the problem maybe?.
maybeyes...
Is it so hard to unsolder the chip and check???
And you may change the chip by new one supporting!
СообщениеДобавлено: 13 авг 2014 00:13
1 problem solved, when unsoldering the chip i could flash the chip with no problem.
but the new dump it's not working, the laptop goes on and off. :ny_tik:
СообщениеДобавлено: 13 авг 2014 06:22
Try to flash. Is verification correct?
СообщениеДобавлено: 14 авг 2014 22:45
To bad also not working
