Текущее время: 14 май 2026 10:30
 Заголовок сообщения: HP 15-AW001NQ Bios
СообщениеДобавлено: 02 май 2017 16:39
Hello, i need a working bios for this laptop, it has the DAG54AMB6D0 REV D motherboard.
Thank you
 Заголовок сообщения: Re: HP 15-AW001NQ Bios
СообщениеДобавлено: 02 май 2017 16:54
Thank you
may be error in DA ...
СообщениеДобавлено: 02 май 2017 18:35
what is DA?
СообщениеДобавлено: 02 май 2017 19:08
Max, I think no fault in MB marking. Just now looking on MB with i3-6100U on board , marking same as DAGblablabla.
СообщениеДобавлено: 02 май 2017 19:38
oh, you meant the motherboard model? i'm sure it's correct because i searched google and could not find it either
СообщениеДобавлено: 02 май 2017 19:41
Just a piece of cake ) from official site
https://comsystem-tlt.ru/Bios/HP/081FB.7z
https://comsystem-tlt.ru/Bios/HP/081FD.7z
СообщениеДобавлено: 03 май 2017 11:33
Thank you, it worked but i'm not sure if it is complete or the right one. It doesn't show the discrete graphics in device manager, only the integrated one
СообщениеДобавлено: 03 май 2017 17:36
Find out what is your BID
СообщениеДобавлено: 03 май 2017 17:48
I did not find such a fee even in the closed part of the Internet
СообщениеДобавлено: 03 май 2017 18:16
...I found in 10 seconds..
СообщениеДобавлено: 03 май 2017 19:48
Sadly i can't find BID in the original dump but i suspect the bios is corrupt because of a failed bios update so maybe it's not there
[url]here are some pictures of my motherboard, mine has discrete graphics[/url]
СообщениеДобавлено: 03 май 2017 19:55
sorry, i had a bad hex viewer the BID is $BID081FD.......F.23
and the pictures are here
СообщениеДобавлено: 05 май 2017 10:21
i've tried other bios versions from the hp website, still windows only sees the integrated graphics so maybe the discrete graphics chip is dead
