Текущее время: 27 май 2026 11:50
 Заголовок сообщения: toshiba c855-13c pskcee-09000eg4
СообщениеДобавлено: 06 дек 2013 00:27
hello everybody i need a bios for toshiba c855-13c pskcee-09000eg4 i5-with ati radeon
привет всем я нужен биос для Toshiba C855-13C pskcee-09000eg4 i5-с ATI Radeon
*problem black screen
 Заголовок сообщения: Re: toshiba c855-13c pskcee-09000eg4
СообщениеДобавлено: 19 мар 2014 13:57
Hello. I have the same problem. I tried REFLOW and REBALL of AMD CHIP, didnt worked, there are two options: the chip is wrong in my case or it´s just not caused by the graphic card. My post test card says 04 F1 that should be graphic.... im gonna change the chip for new one hope it will help.
СообщениеДобавлено: 19 мар 2014 15:44
It will help every time.
REFLOW and REBALL are wrong actions...
СообщениеДобавлено: 25 апр 2014 15:09
Hello.
Got report from chip change. I changed the SJTNV Intel for new one still same error: 04F1 (Graphic card) One G.C. is in CPU, changed CPU too, not working.... Someone can help?
СообщениеДобавлено: 27 апр 2014 09:45
cumelsk
Try to flash BIOS first (save the backup!). Send the full model name (C85x-xxx PSKxxx).
