Текущее время: 11 июн 2026 20:09
 Заголовок сообщения: toshiba L850 plf/plr/csf/csr dsc bios 216-0833000
СообщениеДобавлено: 29 мар 2016 17:47
Hello please upload bios for toshiba l850-b147 pskdlv with video chip 216-0833000.thanks
 Заголовок сообщения: Re: toshiba L850 plf/plr/csf/csr dsc bios 216-0833000
СообщениеДобавлено: 29 мар 2016 18:11
Stock bios support this chip.
СообщениеДобавлено: 30 мар 2016 08:56
i put bios i get no display but num lock and caps lock work also the hdd boots but no display on external and on lcd this is sure bios as i faced same problem with sony sve151aw11. does anyone have working dump with same video chip thanks
СообщениеДобавлено: 30 мар 2016 10:59
Stock bios MBX-266 support ONLY Thames Pro (216-0833002), Thames XT (216-08333000) will work after editing ID (1002-6841 to 1002-6840).
PLF/PLR/... DSC from factory has on board Thames LE (216-0810028) and Thames XT (216-0833000), so bios support this chips. :)
СообщениеДобавлено: 30 мар 2016 12:46
can you post working dump for toshiba l850 here pls thanks
