Текущее время: 14 май 2026 17:42
 Заголовок сообщения: Samsung rv511
СообщениеДобавлено: 31 мар 2014 16:16
I received the following question from another forum. This is exactly what is happening as they say. After updating the BIOS of the device update issue was giving ME at every boot. I obviously did not mind it a lot. Samsung's original software did not update the BIOS on the device, but it did not go with a warning message. And a full 28 minutes after the device shuts itself ...
I have the same issue on my Asus N71JQ. The original error message was "Error sending End Of Post message to ME". I had the CMOS and BIOS chips replaced, now when I power on my laptop the CPU fan runs at 100%, I get the error message "ME FW Update Failed, please try again", then it boots up into Windows and runs for about 15 minutes and powers off (CPU fan at 100% during the entire period).
Became clear that the problem stems from the bios. Intel Managemenet Engine as if protecting a system against theft device. Full half an hour is closing device ...
Thanks to everyone
 Заголовок сообщения: Re: Samsung rv511
СообщениеДобавлено: 31 мар 2014 18:26
What are you want?
What is your question???
СообщениеДобавлено: 01 апр 2014 19:31
ı need you me clear bıos dump
СообщениеДобавлено: 02 апр 2014 10:29
Try to flash (save backup first!):
Зарегистрированные пользователи: Google [Bot], Yandex [Bot], yrik_kvts
