Текущее время: 04 апр 2026 17:43
 Заголовок сообщения: How to extract Lenovo B50-30 Bios and EC if possible
СообщениеДобавлено: 04 окт 2016 11:24
OK here it is. I want to learn to extract main and EC bios for this notebook because it is very specific, the exe file can't be extracted with UniExtractor, instead I used PE Explorer method from this link: http://www.vlab.su/viewtopic.php?p=33735#p33735
The notebook is:
Lenovo B50-30 Model: 20382
ZIWB0/B1/E0 LA-B101P Rev.1A
2014-06-12
Intel® Pentium Processor N3540 (SR1YW)
nVidia N15V-GM-S-A2
Multi: Nuvoton NPCE288NA0DX
First I go to Lenovo support and enter machine make and model and I got bios file for download: 9ccn35ww.exe
When I try to extract with UniExtractor I receive the following message:
Than I use PE Explorer and get this:
After that I open the exe file with WinHex and mark the beginning 1D200
And the end: 1D200 + 4F998 -1 = 43CB97 (it is the end of file anyways)
And make a new file from this data: download
New file is 4.12MB but original bios is 8MB. What to do next with this? I am stuck here.
My uploaded bios file is here and it is 8MB.
What next? Thank you!
 Заголовок сообщения: Re: How to extract Lenovo B50-30 Bios and EC if possible
СообщениеДобавлено: 04 окт 2016 14:47
СообщениеДобавлено: 05 окт 2016 23:19
Thanks to Фрекауцан Михаил (дядьмиша), I now know how to extract bios from this file. If someone is interested, here it is how to do it:
Download: Universal Extractor 1.6.1.1020 от korosya, if this link is not working, try the website
Than unpack it to a folder of your choice and use it on a file you need to be unpacked. After fist unpacking you will get this:
After that, use Uniextract once again on the first file 9CCN35WW,1.EXE and you will get this:
The file Merge.bin is our needed file with bios images. Inside there are couple of images. Use your favorite hex editor and search for string: _BIOSIMG. From the row below starts your main bios image.
Than look for _EC_IMG and from the row below it, start your EC bios.
Copy the required lenght into new file and save both bioses.
Thats all.
Большое спасибо Фрекауцан Михаил (дядьмиша).
СообщениеДобавлено: 06 окт 2016 00:15
СообщениеДобавлено: 07 окт 2016 21:58
[offtop]
The Bios of Lenovo is packed "Inno Setup Packer".
Оnce one method how to make unpacking bios of Lenovo:
1. download The Inno Setup Unpacker from http://innounp.sourceforge.net.
2. make in shell: innounp BiosOfLenovo.exe
3. you get directory named "app" where located "clean" files which you can unpack using 7zip-like unpackers.
4. Take file Merge.bin and cut it...
[/offtop]
Зарегистрированные пользователи: Google [Bot], portartur
