Текущее время: 04 апр 2026 13:21
 Заголовок сообщения: Lenovo NM-361
СообщениеДобавлено: 19 авг 2021 16:59
Hi friends, can you help me anybody please with correct bios dump and EC dump for IT8586-FXS?
Lenovo NM-361
Thank you very much!!!
 Заголовок сообщения: Re: Lenovo NM-361
СообщениеДобавлено: 19 авг 2021 19:51
nm-a361
nm-c361
СообщениеДобавлено: 19 авг 2021 23:31
i am sorry, my mistake. NM-C361
thank you.
СообщениеДобавлено: 19 авг 2021 23:54
https://forum.laboneinside.com/viewtopic.php?t=12233
СообщениеДобавлено: 23 авг 2021 23:41
try this ,
usually works if there are close models, I put and went, or look for a kb the same on lenovo
СообщениеДобавлено: 24 авг 2021 00:55
i try it, EC and bios, but led4 nonstop flashing and laptop black screen.... :(
i dont know, where is problem.
СообщениеДобавлено: 24 авг 2021 17:56
if led blinking , mean ec is good. the issue is in other part. easy way , check every pwm inductor 3-5v, 1.05 pch, 1.35memory. if you have low impedance or short circuit. most important visual inspection if burn out components , oxidat or missing. very important. you need to know average consumation on this stage, for that you need a bench power supply and so
