Текущее время: 25 май 2026 11:42
 Заголовок сообщения: Lenovo G50-70 20351 ACLU1 ACLU2 NM A271 REV 1.0
СообщениеДобавлено: 25 июн 2014 16:40
The machine switches on but no data on the screen. The screen backlight keeps flashing on and off.
 Заголовок сообщения: Re: Lenovo G50-70 20351 ACLU1 ACLU2 NM A271 REV 1.0
СообщениеДобавлено: 26 июн 2014 09:26
Try to flash, and send the result...
СообщениеДобавлено: 26 июн 2014 20:39
Thank you. I programmed with your dump and now the display goes dark black when the machine switches on, tried the hdmi output but still no display data can be seen. Will try see if there is something wrong. The machine is brand new dead out of the box.
СообщениеДобавлено: 26 июн 2014 21:26
And test the dump:
СообщениеДобавлено: 30 июн 2014 18:17
The first dump you provided has now worked well. Thank you. Only thing it has svp.
СообщениеДобавлено: 30 июн 2014 18:52
bridx писал(а):
..Only thing it has svp.
It has what?
СообщениеДобавлено: 30 июн 2014 20:04
Supervisor password. Am unable to enter the bios setup.
СообщениеДобавлено: 30 июн 2014 22:06
bridx писал(а):
Supervisor password...
The dump above assembled from your backup (first half, PCH Region) and working second half (Bios Region) from here.
If SVP existed, it was in your PCH Region.
You will try to flash the next official dump:
Вложение:
9ACN25WW.RAR
But, I think, it will no effect...
I think, SVP stored at EEPROM of special controller or HUB, and will replicate in BIOS flash at first start.
See here...
СообщениеДобавлено: 31 авг 2016 18:57
for what is jme1 pins reset?
