Текущее время: 03 май 2026 21:34
СообщениеДобавлено: 19 май 2010 02:04
OPTION GTM 380 Model: M00301-11169
Бу, гарантия 6 месяцев, безусловный манибек 3 дня. Падать по цене готов от 5 штук. Возможны бартеры на ноутовскую комплектуху по взаимной договоренности. Вопросы в личку или по тел:
МТС (812) 920-4525
Мегафон (812) 946-8862
ТТХ:
Feature
* Global connectivity with triple-band 3G and quad-band 2G
* Multimode HSUPA / HSDPA / UMTS / EDGE / GPRS module
* A-GPS / S-GPS Positioning
* Multimedia features of Qualcomm baseband chip
* Type 3 Advanced Receiver Technology allowing Receiver Diversity and Equalization at the same time
* High-speed data with HSPA (HSDPA / HSUPA) (up to 7.2 Mbps downlink and 2 Mbps uplink) and UMTS and backward compatible with EDGE / GPRS data connectivity (up to 247 Kbps)
* Transparent hand-over between UMTS and GPRS / EDGE networks
* Low power dissipation for easy embedding into devices
* Benefits from large Option experience in PC datacards
* Easy integration made possible thanks to:
* Testing on infrastructures and networks worldwide
* Flexible driver design providing both NDIS and modem modes for easy integration into dashboard applications
* Future proofing through Flash Memory technology
* Connectors for external antennas
Specifications
* Multi-bands variants (bands with Rx diversity areunderlined)
o MO 0301: 850 / 1900 /2100(Rx diversity) MHz
* Power Class 3 (+24 dBm)
* HSUPA mode: 2 Mbps : category 5
o HSDPA modes:
o HSDPA 1.8: Categories 1-4, 11 and 12
o HSDPA 3.6: Categories 5 and 6
o HSDPA 7.2: Category 7 and 8
* Equalization and Rx Diversity at the same time
* UMTS: 384 Kbps operation in downlink, 384 Kbps in uplink
* Support UL and DL Compressed Modes
* Circuit-switched data: 64, 14.4 and 9.6 Kbps
EDGE
* 850 / 900 / 1800 / 1900 MHz
* GSM Power Class 4 (2W) for 850 / 900 bands, GSM
* Power Class 1 (1W) for 1800 / 1900 bands
* EDGE class E2 (+27 dBm in 850 / 900 bands, +26 dBm in 1800 / 1900 bands)
* GPRS / EDGE Multislot Class 12 (4 slots Rx, 4 slots Tx)
* GPRS / EDGE Class B Type 1 MT
* GPRS CS1-CS4; EDGE MCS1-MCS9
* Circuit-switched data: 14.4 and 9.6 Kbps
Assisted/Stand-alone GPS
* A-GPS and S-GPS modes, as described below:
* MS-based, MO of MT
* MS-assisted, MO of MT
* Stand-alone
Terminal Equipment Interfaces
* USB 2.0 signalling
* AT interface with standard modem emulation
* NDIS and Modem interface drivers
o NDIS for OS compliance and future proofing (Vista)
o Modem interface to allow 3rd party application support
* EAP-SIM / EAP-AKA support
* Operating Systems supported:
o WindowsTM2000 SP4 / XP Home / XP Professional / Vista
o Tablet XP Pro / Mac OS X Tiger
* Power Requirements:Vcc 3.3V +/- 9%
Hardware specifications
* Operating Temperature: -10 to +55°C
* Extended Operating Temperature: -25 to +75°C
* Storage Temperature: -40 to +85°C
* Humidity: 5 to 95% no-condensing
Approvals & Certifications
* All applicable regulatory approvals, Operator and Infrastructure IOT
* Microsoft certified drivers
* R&TTE (900/1800/2100) and FCC (850/1900)
* GCF (900/1800/2100)
* RoHS Compliant
СообщениеДобавлено: 21 май 2010 07:30
а как им пользоваться?
СообщениеДобавлено: 21 май 2010 12:10
Думаю разберетесь, если до этого форума добрались :)
