Текущее время: 25 апр 2026 14:01
 Заголовок сообщения: Samsung NP550P7C-T04DE
СообщениеДобавлено: 07 дек 2016 16:49
Strange Samsung problem I have, I think it is the BIOS problem, but I wait you to confirm.
Here is the dump image from notebook, both Main and EC.
http://www.mediafire.com/file/2ab89xx2x ... PTC%29.rar
From both pictures on board and dumped image it's AAA revision BIOS.
The strange thing is the EC bios. When I download any BIOS dump from this or other forum, the EC bios of AAA revision is not the same like the bios in this notebook. The beginning is not the same. But when I download ABI revision BIOS, the EC beginning is the same as in this motherboard.
When I program into the chips downloaded AAA revision, the notebook is dead, no 3.3V and 5V Alive voltages, the notebook won't turn on, nothing, dead...
When I program ABI revision, the notebook has 3.3V and 5V alive, but when I turn it ON, no voltages on CPU and GPU coils.
Can you provide working bios for this notebook? Everything I have downloaded it's not working.
On Samsung website I cannot download BIOS, because now they give only application to download bios on working notebook.
 Заголовок сообщения: Re: Samsung NP550P7C-T04DE
СообщениеДобавлено: 07 дек 2016 20:08
viewtopic.php?p=723900#p723900
P10AAA
also EC in MAIN starting at 500000h
СообщениеДобавлено: 07 дек 2016 20:12
viewtopic.php?f=391&t=103283&p=609849&hilit=MCLAREN#p609849
viewtopic.php?f=391&t=113580&p=675350&hilit=mclaren#p675350
try this dump's
СообщениеДобавлено: 07 дек 2016 20:50
http://notebook1.ru/forma1/viewtopic.php?p=723900#p723900
P10AAA
Already tried it, the laptop is completely dead with this dump. Original EC seem that is starting at 4FF010 but the start is different, and the rest of the file is same as main, please check images.
Beginning is not the same, it's starting at 4FF010:
A little more down, the file is the same:
Middle of the file, it is still the same:
It seems that it's not regular EC file inside the laptop starting at 500000. EC file looks more like ABI revision.
СообщениеДобавлено: 07 дек 2016 20:52
maximus777now писал(а):
http://notebook1.ru/forma1/viewtopic.php?f=391&t=103283&p=609849&hilit=MCLAREN#p609849
try this dump's
These dumps are only MAIN, no dumped EC files.
When I make EC files from main, starting at 500000, the notebook won't start, no voltages...
СообщениеДобавлено: 07 дек 2016 21:59
This motherboard (in normal condition) must have reaction on power button with either EC versions: AAA and ABI
after power on EC piece will be overwritten from MAIN (starting at 50000h) and not necessary will be the same
Try program ABI in EC, and AAA in MAIN ) don`t forget short Cmos Reset points with cmos battery on board and turn on without it
СообщениеДобавлено: 07 дек 2016 22:28
I will try and let you know.
СообщениеДобавлено: 16 дек 2016 17:01
You are the MAN!!!
I flashed ABI in EC, and AAA bios in main. Then I shorted CMOS Reset beside RAM for about 1 minute while the CMOS battery was in the motherboard. Than I pulled the CMOS battery out and unshorted CMOS reset and turned on notebook.
It works!!!
