Текущее время: 03 май 2026 21:51
Форум закрыт Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней.  [ 1 сообщение ]
 Заголовок сообщения: AD-7590A and AD-7591A primary/secondary master softwaretool
СообщениеДобавлено: 05 авг 2008 11:36
The AD-759xA will be distributed configured as "primary Master".
If your notebook`s device slot needs to be configured as “secondary“ master, after build in may errors occur as wrong identification (slave),
slow speed (IDE1/ pio) or finally no detection.
>You can use tool from Notebook if drive will be recognized
or from a desktop pc by using an "IDE“ to “JAE KX15-50ELD1L“
Adapter
>Using tool is only via Windows possible, other operating
systems won`t be supported.
>Both models AD-7590A and AD-7591A can be used with it.
Softwaretool for primary/secondary Master setting can be downloaded below:
G590A_ATAChange_Tool.zip
After usage a reboot of PC/ Notebook is required. You can also
recover setting by using the other tool.
Зарегистрированные пользователи: Google [Bot], uls19, Yandex [Bot]
