Текущее время: 25 май 2026 16:24
СообщениеДобавлено: 30 мар 2014 21:42
Добрый день
Прошу помочь снять пароль на входе Toshiba L655D
InsydeBIOS. Под крышкой оперативки контактов B500 не нашлось.
СообщениеДобавлено: 30 мар 2014 23:21
нашёл отВед в инете:
-----отрезать-------------------------------------------------------------------
The jumper for the L655 is NOT labeled "B500" or "CMOS" or anything like that and is NOT on the edge of the board. It`s directly under the RAM and labeled "G2". There is a clear plastic film over it, but it`s only sticky on the end tabs and easy to peel back. After you take out the RAM, unplug the 4 wire connector next to the RAM, peel back the clear plastic, and use a flat head screw driver to short the "G2" jumper for 10 seconds. Then plug the cable back in and re-install the RAM and you are done. source: How to reset bios password on toshiba satellite l655-s5150?
Was this answer helpful? Yes | No
alexander25 said: it`s work thank you, but i think so the short is g2 to g3 becouse i try g2 short and not work, a then try g2 to g3 and works
Read more: How do I reset my BIOS password on my TOSHIBA Satellite L755-S5112? - TOSHIBA Satellite L755-S5112 is there anyway to reset password on BIOS :: AskMeFast at http://www.askmefast.com/How_do_I_reset ... 73319.html
