Текущее время: 18 май 2026 18:21
 Заголовок сообщения: compaq v3000 no power
СообщениеДобавлено: 22 ноя 2008 22:48
compaq v3000 i got for repair with no power i changed the dc-dc max8734a and also mosfet 4422 now the power light at the dc socket comes but there is no 5v or 3.3 volts the north brige nvidia nf-6150-n-a3 what is the ohms on the multimeter to show as it show 3ohms i feel it is short also does anyone now the ball pitch size of nf-6150-n-a3.thanks any one have schematics for this model can email me.
repairs of laptops and selling of components
СообщениеДобавлено: 22 ноя 2008 23:08
Mainboard will be power on without north bridge :)
Ball pitch nf 6150 is standard. 1.00mm
СообщениеДобавлено: 23 ноя 2008 13:20
afaik, 6150go doesn't need 5v :) it seems, that the northbridge is dead, 3ohm - isn't normal!
 Заголовок сообщения: re nf6150 nvidia
СообщениеДобавлено: 24 ноя 2008 21:34
does anyone know the reflow profile for nvdia chpset what the temp/sec should be for bga desoldering I am using a bga rework with a infr red heater and need to know the temp profile.
СообщениеДобавлено: 25 ноя 2008 10:39
the profile should be: 1 dg per seconds till 160dg, then 5 seconds delay, then again 1 dg per seconds till 235dg. this is working profile, which used by me :)
 Заголовок сообщения: re v3000
СообщениеДобавлено: 02 дек 2008 13:57
okay now i removed the south bridge and the shorting has gone the n6150 is now showing 6.5ohms but after i removed the south and the north bridge it give me only 3.3v and sometimes 5v stdy power does the south bridge have to be there for the dc-dc to work. does any one have idea on this also what is the ball pitch size for southbridge(nf-430-n-a3) and ball pitch size for nf-6150-n-a2.
СообщениеДобавлено: 09 дек 2008 21:08
okay now that i have pulled out the southbridge and the northbridge i dont have 3.3v or 5v coming from max8734a does the southbridge have to be present for reset or is there a shtdn sigal come from southbridge for the dc-dc.also hom many ohms should the northbridge measure.i have a reading on some points 120ohms and some 6.8ohms.can someone verify this
СообщениеДобавлено: 10 дек 2008 13:34
the ball pitch size is same for southbridge and northbridge(0,6mm size of the ball and 1mm distance between centers of balls). there'll be no standby voltages without southbridge.
 Заголовок сообщения: re lamo
СообщениеДобавлено: 11 дек 2008 21:48
hello lamo,
thanks for your advice i will put the south bridge chip but will it turn on without the northbridge chip as i have removed both of them i have a dead southbridge shorted so the supply drop 3.3v.lamo do you have schematics for this v3000 or dv2000 series amd they have all same problem i get 4 laptop every week with same problem.and have just got a new infrared machine dark region for bga soldering so to set profiles it take time.
the intel south bridge heat profile will be the same for it .235deg .
