Текущее время: 15 мар 2026 20:25
 Заголовок сообщения: Asus X550DP main board, no light on LED panel
СообщениеДобавлено: 16 мар 2016 01:32
Hello to all. I received an ASUS notebook for repair. There is no light on laptop screen but the picture is visible and everything else is working.
The motherboard is ASUS X550DP. I cannot find the schematic only the repair guide which is uncomplete.
Here is a picture to explain the problem a little better:
Part 1 is blown, I assume it is a coil - L (short), because user can choose which voltage will go into LED panel.
On left side there is 3.3V supply voltage, and if the coil is put there than 3.3V will go to the LVDS connector, if the coil is put on the right side, 5V will go to the LVDS connector.
Also the Realtek translator IC (eDP to LVDS) is heating a lot. I am maybe missing LED turn on voltage and can't find the schematic to see what controls it to turn on..
Any help is appreciated.
Thank you!
ASUS_X550_PD.jpg [ 251.51 КБ | Просмотров: 663 ]
 Заголовок сообщения: Re: Asus X550DP main board, no light on LED panel
СообщениеДобавлено: 16 мар 2016 07:26
replace RTD2136
"Part1" +3V to +3V_CAMERA
Зарегистрированные пользователи: Google [Bot], SergAN2, Yandex [Bot]
