Текущее время: 04 май 2026 18:25
 Заголовок сообщения: Inspiron 3721 (LA-9104P) replaced CPU now I get 7 beeps
СообщениеДобавлено: 23 май 2017 23:35
Hi guys,
I replaced the CPU (Pentium SR0VQ) on this LA-9104P (it was dead before) and now I get 7 beeps.
I have flashed EC and PCH bios chips with good dumps.
I have NOT flashed KB9012 because I try with Vertanov's programmer and a 1.0mm to 0.8mm / 30pin adapter but the I/O is not detected.
The laptop turns on, LED ok, FAN ok but after a while I hear 7 beeps from the speaker.
Any ideas?
Thank you in advance,
BR,
george
 Заголовок сообщения: Re: Inspiron 3721 (LA-9104P) replaced CPU now I get 7 beeps
СообщениеДобавлено: 24 май 2017 00:19
It seems that the VCC_Core is not coming up - but there is not a short (?), diode mode measurement 0,001 (around 3ohms).
The PWM was replaced (the ENable signal is present at pin2 of ISL95833H) but still no voltage..
I lifted the coil (PL701) and injected 1V - there is a maximum 1,3A current draw - no more than that. Nothing gets hot of course with so little wattage..
You think its a bad CPU? I have replaced many without problems (using Finetech Fineplacer PICO RS so not easy to kill the chip)
br,
george
