Текущее время: 22 май 2026 07:50
 Заголовок сообщения: Hp pavilion 14-n007ax
СообщениеДобавлено: 21 янв 2015 20:25
hp pavilion 14-n007ax DA093MB6D0 bios bin required? please
 Заголовок сообщения: Re: Hp pavilion 14-n007ax
СообщениеДобавлено: 21 янв 2015 20:26
DA0U93MB6D0..
СообщениеДобавлено: 23 янв 2015 04:53
Вложение:
F15_BID0216D.RAR
Вложение:
F15_BID02169.RAR
See the "BIDxxxxx" at the end of your original main backup, and flash the same.
СообщениеДобавлено: 23 янв 2015 10:41
thanks..
СообщениеДобавлено: 23 янв 2015 11:02
OK i didn't find EC bios separate in this board only one main bios so what you suggest?
СообщениеДобавлено: 23 янв 2015 15:16
after flashing this file now charging battery light on power on/off ok 3v, 5v, 1.5v,1.8v,.8v on cpu 02 coil are ok but no display the missing voltage are on two coil one which is driving by ic ADP3211 i think this is GPU voltage is missing .
the key board Caps-lock light is blinking and wifi red light is continuously on.
so what you experts are advise and i have no schematic for this,if any one have please share.
СообщениеДобавлено: 23 янв 2015 19:56
Not have schematic, sorry.
What is the "BID" you have flashed?
What is the Platform ID of your laptop? (See it under battery.)
Caps Lock Continuous blink - may be AC adapter wrong...
Check CPU, memory, CMOC battery, etc.
СообщениеДобавлено: 24 янв 2015 10:18
Ok thanks
i tested both BID because the old dump was not available the chip was written by wrong file a technician and did,nt backup.
now the working BID02169 because it is normal compare to the other BID0216D.
Under the battery i found...Rev:216E-100 and PCID: 0887100000005E00000600000.
the Caps-lock blink continuously both on adopter and also on battery.
one the thing i want to mention it is AMD processor with AMD graphics BGA.
i think there is something wrong with IC ADP3211 because on the connect coil has no voltage whats your suggestion.
Thanks and i am waiting for your advise.
СообщениеДобавлено: 24 янв 2015 10:25
one thing i want to mention also is the the FAN is spinning continuously.
СообщениеДобавлено: 24 янв 2015 14:27
I think it is for BID0216D, reflash!..
Replace CPU, memory, by 100% working for test. Check CMOC battery.
Check all power voltages on board include all LDO voltages (found everything!).
You will check it using datasheet.
http://www.onsemi.ru.com/pub_link/Colla ... 3211-D.PDF
Define BGA chipset - video, north, south...
