Текущее время: 29 апр 2026 05:17
 Заголовок сообщения: ASUS x58L
СообщениеДобавлено: 16 сен 2010 16:41
Hello, could you please help me, Im desperate.
I have ASUS x58l laptop, and I need to remove bios pasword. before this problem, I just set wrong pasword 3times, pressed f2 and windows started. I tried to take out battery, but it doesnt work. Could you please give me some advice. Thanks.
(I understand all in russian, I just cant write in russian with my keyboard) Thanks
 Заголовок сообщения: Re: ASUS x58L
СообщениеДобавлено: 16 сен 2010 16:55
Дату показывает ? Какую ?
СообщениеДобавлено: 16 сен 2010 17:04
Ne pokazivajet. when I set wrong password 3times it shows just:
"Password check failed
Press F2 to resume"
But I cant press F2
СообщениеДобавлено: 16 сен 2010 17:05
Kak ja mogu uznatj daty?
СообщениеДобавлено: 16 сен 2010 17:12
тут читал ?
viewtopic.php?f=52&t=19367
как раз способы описаны
СообщениеДобавлено: 16 сен 2010 17:16
I just find this tutorial, now I will try to use this. Hope it works. Thanks.
СообщениеДобавлено: 16 сен 2010 19:09
I just show this tutorial to my computer guy, he said that he tried all things what is written there, but it still doesn't help. So maybe there is other ideas. He said that only option is to braze motherboard, but it is not recommended, because it can make serious damage for motherboard. Please help with your suggestions.
СообщениеДобавлено: 21 сен 2010 21:08
Can you please help me with your suggestions?
СообщениеДобавлено: 21 сен 2010 21:48
Так с паролями вам нужно в соседний форум по паролям: viewforum.php?f=52
А писать можете и латиницой на русском языке. Удачи!
