Текущее время: 07 май 2026 17:53
 Заголовок сообщения: hp 6720s windows installation
СообщениеДобавлено: 25 фев 2012 13:49
hello i have 2 laptops hp6720s when go to install win7 or vista wixp the installtion start and after 10% of loading files it just shutsoff.i have changed bios and also the bios chip and changed the southbridge chip same error
 Заголовок сообщения: Re: hp 6720s windows installation
СообщениеДобавлено: 25 фев 2012 15:11
test cpu power
test \ replace memory
test hdd
maybe bad peripherial device near southbridge
(water in cardrider ... )
СообщениеДобавлено: 26 фев 2012 21:10
Hello thanks for the reply
The hdd and ram ihave changed also changed various cpu and the bios chip and bios program and thee is no heatin as when i use winxp live cd windows mini is works fine.also i have load the windows in other laptop andthenput that hdd in the faulty laptop when it boots it goes off the board is fresh no crosion onit.
I feel the cpu section may be a problem
СообщениеДобавлено: 26 фев 2012 21:32
If to change the power supply ?
СообщениеДобавлено: 02 мар 2012 23:40
Power all ok. I suspect the bios i need dump from workin laptop anyone have pls upload
СообщениеДобавлено: 27 мар 2012 15:44
Check what type of CPU installed. Some motherboard revision work only with Intel Celeron M 530. Try with Intel Celeron M 530. If processor has been replaced to another (at example Intel Core 2 Duo T7250) you have problem with integrated video after Power on. If you go in bios settings, F10 and save, after this reset win7 starts ok. If you work with ext. monitor the win7 starts ok after power on.
with windows Xp: bluescreen
with windows 7:photo
http://piccy.info/view3/1591194/f9879d9 ... e9f6/1200/
СообщениеДобавлено: 27 мар 2012 17:25
or try Celeron M540 (FSB 533Mhz)
СообщениеДобавлено: 27 мар 2012 18:10
maybe overheat?
СообщениеДобавлено: 30 мар 2012 23:08
Hello
The problem was with the 965 graphics as the pll voltage 1.25v would drop after the graphic chip heat as when windows load it would put more load on the intel integrated graphic chip
Thanks all for replying it was a coincidence with 2 board same fault
