Текущее время: 07 май 2026 05:59
 Заголовок сообщения: nx7400 hp boot error
СообщениеДобавлено: 15 мар 2012 22:42
Hello
I have a hp nx7400 laptop the problem it does not boot from cd or usb or hdd i have replaced the bios and also the intel southbridge ic.same problem what is the problem with this machine
 Заголовок сообщения: Re: nx7400 hp boot error
СообщениеДобавлено: 16 мар 2012 04:05
Not boot , but recognise ODD and HDD in BIOS or .. ?
Try to check 5 volt power for drives and USB ports. If ok - explain here more details about fault.
СообщениеДобавлено: 16 мар 2012 11:09
hi thanks for the reply well the bios does recinize the hdd and the cdrom also the 5volts is there for the usb when i do test in the bios for hdd it show that the test is sucessful.what signal to check for southbridge for boot
