Текущее время: 25 май 2026 18:07
 Заголовок сообщения: BIOS RESTRICTIONS
СообщениеДобавлено: 05 сен 2014 15:19
Hello.
We all already know why we cant put in laptop any WIFI card or any graphic card even MXM 2 /3.
We have some experience with changing Vendor ID in BIOS when we need put there non original WIFI card, just read new wifi Vendor ID and replace it inside of BIOS.
We were thinking about the same with the graphic cards (mxm 2/3 ) we need one laptop supporting all graphic cards someone tried it before? :) We need test all kinds of cards.
If not we will look to it ourselves, but it would be nice someone to help, maybe we can make it faster.
Peter :du_ma_et:
 Заголовок сообщения: Re: BIOS RESTRICTIONS
СообщениеДобавлено: 05 сен 2014 16:24
.....what the nature of your problem?????
СообщениеДобавлено: 17 сен 2014 12:08
My problem is that i insert MXM card to laptop and it dont work at all laptops, i want make one laptop wich you can test cards on, all of them, need change BIOS restriction, that block non-supported cards.... We have planty of MXM 2 cards and no way to test them
СообщениеДобавлено: 17 сен 2014 12:23
one laptop for all cards - it`s impossible )
СообщениеДобавлено: 17 сен 2014 12:24
...to check the ATI and Nvidia MXM-2 I used ICL-50 LA-3551P motnerboard...
...results are very good..
СообщениеДобавлено: 22 сен 2014 13:22
Thank you, i ll look for it, anyway, if we find way to remove restrictions we will writte here, it should be possible to make work any card in any laptop, all whats matter is that the cards are denied in BIOS, so laptop wont turn on screen or after turn on writte: " ERROR: Hardware is not compatibile, please remove it"... it could at least increase the possibilities, as i said, it works for WIFI cards (Vendor ID change in BIOS), if should work for MXM cards too, just too much work with it.
