Текущее время: 23 апр 2026 06:51
 Заголовок сообщения: Toshiba Satellite Pro L300 (6050A2264901-MB-A03) need help
СообщениеДобавлено: 16 янв 2016 16:52
Hello to all,
I need help with Toshiba Satellite Pro L300 motherboard. Someone already tried to repair it and I think he moved some of the components around the standby controller. Here are the pictures of the board and standby controller zoomed in. If someone have the same board, please take a picture of it and post it.
Thank you!
Изображение Изображение Изображение Изображение
 Заголовок сообщения: Re: Toshiba Satellite Pro L300 (6050A2264901-MB-A03) need he
СообщениеДобавлено: 16 янв 2016 18:05
Repair this capacitor.
20160116_122401.jpg [ 348.19 КБ | Просмотров: 496 ]
СообщениеДобавлено: 16 янв 2016 20:12
I know about NEC Tolkin capacitors, I have exchanged them a milion times but it's not the problem here.
Standby controller is overheating, no voltages on chokes, something not right with standby voltages...
Motherboard won't turn on.
СообщениеДобавлено: 16 янв 2016 20:23
There are two possibilityes for "boiling" 51125 - 1) shorted load; 2) 51125 is dead. check load resistance on both chokes and on 8 and 17 pins.
СообщениеДобавлено: 16 янв 2016 20:30
I have no such mobo at home, but for me it does not look like something is missing around PWM. It will took you 10 minutes to compare with principial scheme of mobo which is available for free or typical application circuit of controller
СообщениеДобавлено: 16 янв 2016 21:12
I already exchanged the TPS51125 for a new one, and changed KBC with other one, the same problem exists. No one from my colleagues has this motherboard so I can't compare it.
СообщениеДобавлено: 16 янв 2016 23:27
please, could you tell us measured resistance values from pins 8, 17, 11, 20 to gnd, in case it isn't a military secret :-)
