Текущее время: 30 апр 2026 23:30
 Заголовок сообщения: lenovo yoga 3 14 "/ NM-A381/ help to program IT8386E
СообщениеДобавлено: 23 апр 2018 13:17
Hi ,
This motherboard doesn't start , so i found short on IT8386E
I replaced it, now laptop start but no display .
i think i must program IT
i use programmer with Vertyanov JIG ver 4.C.
When i check connection i have this message "ITE we do not respond, check the connection and settings. MB powered? (00)"
Can you tell me why ? I forgot anything ?
Best regards
 Заголовок сообщения: Re: lenovo yoga 3 14 "/ NM-A381/ help to program IT8386E
СообщениеДобавлено: 23 апр 2018 13:25
Are you sure that this step is 1mm? Not 05 or 08mm
5555.JPG [ 54.25 КБ | Просмотров: 960 ]
СообщениеДобавлено: 23 апр 2018 16:56
i look it's ok
but if i turn cable for aligned pin 1 with pin 1 i lose contact on the connector.
СообщениеДобавлено: 24 апр 2018 13:03
Hi ,
i soldered wires because cable 26 pin not apply contact correctly , it don't orks so i plug motherboard and i can program
But i have other problem.
It start again without dislpay.
Motherboard start when i plug
i replace TPS51716 ; BQ715
i check some voltage :
PL301 0.540v
PJ 303 0.5v
PJ 304 0.17v
what i have to check ?
Best regards
Зарегистрированные пользователи: Google [Bot], hotlin, Yandex [Bot], дока
