Текущее время: 04 мар 2026 13:09
 Заголовок сообщения: Dell D430 - JAU00 LA-3741P fan and display failing
СообщениеДобавлено: 10 июл 2020 14:15
Hello! Need urgent help P.S !
Fixed initially a short on memory bus +1.8V rail by removing on board cells getting hot one by one, till last cell.
Inserted a DDR2 in SODIMM slot1.
Switched lap, all main voltages are ok, but fan and display are failing.
Voltages measured on FAN & Thermal Sensor IC "EMC4000" are attached.
Issues found :
Pin6- FAN_OUT : 0V ?? no spinning.
Pin30- THERMTRIP_SIO : 0V low, I guess, it should be high i.e +3.3V p.s correct.
Pin29- HW_LOCK# : 0V. Is it Hardware lock signal ? Should it be high level i.e +3.3V ? p.s correct.
Any idea on next steps to help solving issues would be much appreciated!
Thank you
DELL D430 not spinning, no display post.docx [13.45 КБ]
 Заголовок сообщения: Re: Dell D430 - JAU00 LA-3741P fan and display failing
СообщениеДобавлено: 10 июл 2020 14:41
Here's the right file to be attached to my post.
Pages de Dell_D430_LA-3741p2.pdf [36.26 КБ]
СообщениеДобавлено: 12 июл 2020 16:31
44 viewers is good, but no suggestion from my professional colleagues is not encouraging.
СообщениеДобавлено: 01 авг 2020 22:41
Surprised not to get any suggestion from any of the 218 viewers.
Laptop was returned to customer. Thread is considered closed.
