Текущее время: 14 мар 2026 04:39
 Заголовок сообщения: Lenovo BIOS extraction
СообщениеДобавлено: 24 июн 2023 18:29
gruj03us.7z
Dear All,
Please help me to extract this BIOS, so that get the bios bin file.
Thank you.
 Заголовок сообщения: Re: Lenovo BIOS extraction
СообщениеДобавлено: 24 июн 2023 20:05
... you provided an update ... it does not have a full bios.... tell me your lenovo model and machine type..
СообщениеДобавлено: 24 июн 2023 20:21
Its Lenovo X1 Carbon Gen 2, Type 20A8. My problem is POST screen is not appears during the startup. So i cannot access the BIOS. That mean i cannot change any setting of the bios, But os is load and operates well. So, i need to solve this problem.
СообщениеДобавлено: 24 июн 2023 22:13
... maybe you have a problem with the MEC1633 dump .. change its firmware ..
СообщениеДобавлено: 25 июн 2023 09:52
Thank you,
I will try.
СообщениеДобавлено: 25 июн 2023 10:02
I've forget to add this, when i reprogram the BIOS then the POST screen appears on firs startup. After that POST screen not appears.
СообщениеДобавлено: 25 июн 2023 15:00
... perhaps before flashing the bios you need to reset the settings by removing the CMOS battery ..
СообщениеДобавлено: 01 июл 2023 19:31
Is there any guideline for this?
СообщениеДобавлено: 02 июл 2023 00:07
... I dare to suggest that you do not have enough experience to solve this difficult task and you are limited in funds. It would be better to contact a service center where your problem could be solved....
