Текущее время: 25 май 2026 18:11
Начать новую тему Ответить на тему  [ Сообщений: 26 ]
 Заголовок сообщения: Asus X551CA-SX024D possible dump?
СообщениеДобавлено: 05 апр 2014 16:02
hi guys is possible to have a full dump BIOS ( 8mb) of this notebook ?
thanks
 Заголовок сообщения: Re: Asus X551CA-SX024D possible dump?
СообщениеДобавлено: 05 апр 2014 16:13
x551ca rev 2.2.
Вложение:
x551ca rev 2.2.zip
СообщениеДобавлено: 05 апр 2014 17:19
finkotbar писал(а):
x551ca rev 2.2.
Вложение:
x551ca rev 2.2.zip
very thanks dear and very greatful.... :-)
This community is very great.
СообщениеДобавлено: 06 апр 2014 04:30
finkotbar писал(а):
x551ca rev 2.2.
Вложение:
x551ca rev 2.2.zip
hi dear ,
i have loaded this file into dediprog sf100, with manual voltage to 2.5 V.
The chipset bios are Winbond W25Q64FV and in config i have selected:
Batch Operations -> Download a whole file to chip ( without blank check) .
Miscellaneous Menu -> Vcc Option --> 2.5 V
-> Spi Clock Setting --> 12MHz
Flash Option ---> unprotect blocks automatic
but during the flash ( batch procedure) appears this message :
Warning : BLocks are protected
what is your opinion?
Ps this is log :
2014-Apr-06 02:26:54: Welcome to DediProg SF6.0.4.30
2014-Apr-06 02:26:54: Start logging ...
2014-Apr-06 02:26:54: Checking Windows version ....
2014-Apr-06 02:26:54: Windows version: Windows 7
2014-Apr-06 02:26:54: Checking USB connnection ....
2014-Apr-06 02:26:54: USB OK.
2014-Apr-06 02:26:55: 0.798s elapsed to identify chip.
2014-Apr-06 02:26:59: Current Type: W25Q64FV
2014-Apr-06 02:26:59: VCC 3.5V is applied.
2014-Apr-06 02:27:07: Advanced settings...
2014-Apr-06 02:27:17: Advanced Settings completed.
2014-Apr-06 02:27:18: VCC 2.5V is applied.
2014-Apr-06 02:27:18: Warning: Enable auto unprotect block.
2014-Apr-06 02:27:18: Warning: Batch with erase.
2014-Apr-06 02:27:34: Loading C:\Users\user\Downloads\X551CAAS210 (1)\chip2.bin ...
2014-Apr-06 02:27:34: C:\Users\user\Downloads\X551CAAS210 (1)\chip2.bin Loaded.
2014-Apr-06 02:27:34: Operation completed.
2014-Apr-06 02:27:34: 0.758 seconds elapsed.
2014-Apr-06 02:27:47: Advanced settings...
2014-Apr-06 02:28:06: Advanced Settings canceled.
2014-Apr-06 02:28:09: Programming parameters:
2014-Apr-06 02:28:09: Source File: chip2.bin(0x800000 bytes)
2014-Apr-06 02:28:09: Target Memory Region: [0, 0x800000)
2014-Apr-06 02:28:09: Spare Memory Region: leave as being erased.
2014-Apr-06 02:28:09: Truncate-File-To-Fit-Memory Disabled.
2014-Apr-06 02:28:10: Identify Chip OK.
2014-Apr-06 02:28:10: Erasing a whole chip ...
2014-Apr-06 02:28:10: Auto unprotect block is enabled
2014-Apr-06 02:28:10: Warning: Block(s) are protected
2014-Apr-06 02:28:10: Unprotecting blocks...
2014-Apr-06 02:28:10: Error: Failed to erase a whole chip
2014-Apr-06 02:28:10: Operation completed.
2014-Apr-06 02:28:10: 0.427 seconds elapsed.
СообщениеДобавлено: 06 апр 2014 07:59
Why??? Standart Vcc is 3.2V (2.7 to 3.6V supply, see datasheet).
Or change the chip by new...
СообщениеДобавлено: 06 апр 2014 13:45
Thank you for having responded to me. I was able to enter v. 2.5 because 3.5 V does not find the chip. The mainboard Is not connected to DC brick and no power button is connected on the mobo.
The firmware of Dediprog is 5.5
On the mobo there is only the cmos battery
What is the problem ?
СообщениеДобавлено: 06 апр 2014 14:35
Hi :)
Tagansiti rights - Standart Vcc is 3.2V (2.7 to 3.6V supply, see datasheet).
and yet - pin 3 (Write Protect Input)
Datasheet W25Q64FV:
"3.12 Write Protect (/WP)
The Write Protect (/WP) pin can be used to prevent the Status Registers from being written. Used in conjunction with the Status Register’s Block Protect (CMP, SEC, TB, BP2, BP1 and BP0) bits and Status Register Protect (SRP) bits, a portion as small as a 4KB sector or the entire memory array can be hardware protected. The /WP pin is active low. However, when the QE bit of Status Register-2 is set for Quad I/O, the /WP pin function is not available since this pin is used for IO2. See figure 1a, 1b and 1c for the pin configuration of Quad I/O operation.
When /WP pin is low the Status Register locked and can not be written to.
When /WP pin is high the Status register is unlocked and can be written to after a Write Enable instruction, WEL=1."
СообщениеДобавлено: 06 апр 2014 14:59
DesCod писал(а):
Hi :)
Datasheet W25Q64FV:
What can I do? I do not have to connect pin3? I did not understand, thank you for your kindness
СообщениеДобавлено: 06 апр 2014 15:16
The best option to buy TL866A :-)
http://www.autoelectric.cn/MiniPro/Index.htm
Look...
СообщениеДобавлено: 06 апр 2014 17:02
programming on the board - a bad decision.
good option for your programmer - Flash Module-SO8W(207mil) socket
СообщениеДобавлено: 27 апр 2014 23:58
Hi guys,
is possible to have a new full dump of x551ca-sx024d with lan ?
thanks
СообщениеДобавлено: 28 апр 2014 12:35
harsan писал(а):
...with lan...
Mean you "with MAC address"?
Try to use bt.exe...
СообщениеДобавлено: 28 апр 2014 13:20
тагансити писал(а):
harsan писал(а):
...with lan...
hi тагансити :-) bt.exe not work in this computer because this has a Aptio Bios :(
there are another solution?
СообщениеДобавлено: 28 апр 2014 13:30
....Изображение....Lay here your dump.... and specify the MAC-address, which must have...
СообщениеДобавлено: 28 апр 2014 13:44
this is a bios
http://cjoint.com/?0DAnzlBlC7u
and mac address are :E03F49301212
СообщениеДобавлено: 28 апр 2014 14:16
harsan писал(а):
this is a bios
Try to flash:
Вложение:
E03F49301212.RAR
Use Flash Image Tool for edition MAC in future...
Последний раз редактировалось тагансити 28 апр 2014 14:22, всего редактировалось 1 раз.
СообщениеДобавлено: 28 апр 2014 14:20
... :nez-nayu: ах Сергей..Сергей...не дал мне карму приподнять.. :-)
СообщениеДобавлено: 28 апр 2014 14:25
тагансити писал(а):
harsan писал(а):
this is a bios
Try to flash:
Вложение:
E03F49301212.RAR
ok, thanks and what region occur operate for insert MAc address?
СообщениеДобавлено: 28 апр 2014 15:04
ME Region => ME Debug Event Service (I think so)...
СообщениеДобавлено: 28 апр 2014 16:55
Ah very thanks тагансити.
How to insert SN and UUID ? Exist a procedure?
СообщениеДобавлено: 28 апр 2014 20:23
For UUID, I think, ME Region => Configuration => FW Update OEM ID.
For SN, I don't know, sorry...
Have you flashed the dump E03F49301212.bin?
What about MAc - is it right?
What is SN displayed at the BIOS page now?
СообщениеДобавлено: 29 апр 2014 13:28
Morning тагансити :-)
still have not been able to work on the pc, because I was not at home these days. In these next few days we work on and I'll tell you :-)
thanks for the kindness in the meantime
СообщениеДобавлено: 05 май 2014 12:36
Morning тагансити
i have put the bios on winbond, but the problem are every this, no Lan Work and no SN
СообщениеДобавлено: 06 май 2014 20:29
Hi, harsan!
Try to use bt.exe under DOS (boot from DOS first).
It should help...
СообщениеДобавлено: 24 май 2014 02:10
тагансити писал(а):
Hi, harsan!
It should help...
Hi dear, I used bt2.exe and cant write :(
because is it so this aptio?
СообщениеДобавлено: 19 авг 2014 18:04
От себя добавлю.
Прошивка сверху чистая, без серийников, MAC-адреса и прочего. С ней получаем нерабочую сетевуху (код 10, запуск устройства невозможен). Чтобы все было ОК - надо перенести из родной прошивки кусок с серийниками (начинается с адреса 230000H, заканчивается предположительно по адресу 280000H).
С помощью BT.exe прописать не удалось.
