Текущее время: 26 май 2026 08:01
 Заголовок сообщения: ene kb910q b4
СообщениеДобавлено: 12 июн 2008 21:09
требуйте datasheet для kb910q b4 пожалуйста кто-нибудь имеет или может сообщение я
repairs of laptops and selling of components
СообщениеДобавлено: 12 июн 2008 23:25
Почетный Мастер
Интеречно, что вам даташит даст? Может с южного моста лучше начнете?
 Заголовок сообщения: re
СообщениеДобавлено: 23 июн 2008 22:46
большое спасибо мой друг
СообщениеДобавлено: 24 июн 2008 01:57
guruji, where you from? Can you find good translater? Your speeches are not clear for us.
Dont think that datasheet will help. Anyway, please, respond about a result.
 Заголовок сообщения: hello
СообщениеДобавлено: 24 июн 2008 22:56
sorry for my russian as I am from India and i try to translate the russian language from a website that why the russian is not good but pls bear with me .will the ene datasheet i wanted is for many acer and toshiba laptop this one acer had no power there was no 3v on pin 2 of ene kb910 which come from a pull-up resistor was open to 3v not the machine works tm2350.I wish the website was in english too as i could help in many faults we works with only laptop chip level and all kinds .if there is anything i can help pls send mail in english and i will help you
thanks again
СообщениеДобавлено: 26 июн 2008 18:10
acer 2350 has many typical faulties, such as: dead southbridge, dead battery charging PWM-controller and broken BIOS ROM(!). i'd suggest to begin with bios rom reflashing.
СообщениеДобавлено: 27 июн 2008 06:51
the problem i have with tm2350 is when you plug the adapter all the lights come on i have reprogrammed the bios but same problem this is a common problem with tm2350 with all lights come on i changed the micom too the kb-910 but same problem .i think the problem is with the south bridge chip as it is not sending pcireset signal.any suggestion
 Заголовок сообщения: Re: re
СообщениеДобавлено: 27 июн 2008 09:51
Почетный Мастер
this is not a correct relacement.
you MUST change EC to KB910Q B4 only.
СообщениеДобавлено: 27 июн 2008 12:44
guruji, if you have lacking of reset signal or "flowing" reset, try to replace southbridge(fw82801DBM, afaik).
Зарегистрированные пользователи: Сергей10, Google [Bot], Yandex [Bot]
